Date/Time: Fri, 10 Jan 2025 13:41:07 +0000
CQG DirectFX support
View Count: 1490
[2016-09-09 13:40:23] |
Napoleon Dynamite - Posts: 54 Invalid SC Account Name. |
Hey, does SierraChart support forex trading coming from DirectFX of CQG ? http://www.directfx.com/en/cqg-fx/It looks like top notch feed and trading conditions...
[2016-09-09 16:20:02] |
Yes Direct FX is supported. You will see the symbols in File >> Find Symbol when Sierra Chart is set to use CQG.
[2016-09-09 17:12:17] |
Please I would like to reach you by email. Can you share it ? or get in touch with my registered email. Thank you
Date Time Of Last Edit: 2016-09-09 17:12:43
[2016-09-09 17:27:03] |
Preferably use an Account Support Ticket: https://www.sierrachart.com/usercp.php?page=SupportTickets Or you can you support _AT_ SierraChart.com Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
