Date/Time: Fri, 10 Jan 2025 13:17:40 +0000
MOVE TO BREAK-EVEN
View Count: 1095
[2016-09-09 12:23:10] |
User82615 - Posts: 106 |
HELLO IS IT POSIBLE TO DESIGN A TRADING SYSTEM IN ACSIL THAT HAS A "MOVE TO BREAKEVEN FOR STOP " ORDER BUT THIS ORDER BASED ON A PERCENTAGE INSTEAD OF A NUMBER OF TICKS , SO WHEN THE PRICE MOVES A PERCENTAGE FROM THE PARENT FILLED ORDER (NOT A NUMBER OF TICKS) THIS ORDER IS ACTIVATED AND MOVES TO THE BREAK EVEN PRICE? IF IT IS POSSIBLE COULD YOU PLEASE EXPLAIN ME A LITTLE HOW IT MUST BE PROGRAMMED IN ACSIL? AND IF IT IS NOT POSSIBLE IS THERE ANY WAY TO SEND A BREAK EVEN STOP ORDER BASED ON PERCENTAGE INSTEAD OF A NUMBER OF TICKS USING A NORMAL INDEPENDENT STOP ORDER ? THANK YOU VERY MUCH IN ADVANCE |
[2016-09-09 16:57:37] |
In ACSIL Attached Order prices need to be specified as price offsets or actual price values. You can always do your own calculations involving a percentage to come up with a price offset or price value. How that is done is not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
