Date/Time: Fri, 10 Jan 2025 13:42:20 +0000
Rollover
View Count: 679
[2016-09-09 10:35:06] |
User865738 - Posts: 16 |
Hi, I have problem with rollover of symbol. I have open december NSDQ e-mini futures. But when I use numbers bar, numbers of orders are wrong. (Bacause this numbers are very low) Can you tell me what I should doing? Thank you |
[2016-09-09 17:39:35] |
To solve this you need to use the Continuous Futures Contract Chart feature: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
