Date/Time: Fri, 10 Jan 2025 14:33:53 +0000
Multiple Volume by price on the DOM chart
View Count: 934
[2016-09-09 10:27:40] |
User60591 - Posts: 39 |
Hi, Is it possible to draw VbP for the last 30 minutes on the DOM chart? i.e. I use market profile so It would be good to see a VbP for the last letter or 30 min bar. Also I tryed to draw a second one form US open till close. I was not able to do it, it starts to draw immediately when i set it up. Can you pls help me with that? thnx |
[2016-09-09 17:24:22] |
Refer to the answer here for this: showing two volume profiles on DOM | Post: 98927 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-19 06:15:35] |
hi, I manage to draw last 30 minutes VbP on the DOM, but I still having problems to draw US session with start at 09:00ET. Idea is to have Globex, US session and last 30min on the same DOM. For the US session: Set independent Volume profile for TPO is set to YES, Use different Start time YES, I have set the Start and End time. I even try to change evening session in chart settings and set Use separate profile for evening session to Yes. Pls advise. thnx |
[2016-09-19 13:18:44] |
solved
[2016-09-19 18:16:43] |
This is good. However, this Input should not be set to Yes: Set Independent Volume profile for TPO when using this study on a chart without the TPO Profile Chart study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-19 18:17:20
