Date/Time: Fri, 10 Jan 2025 13:48:04 +0000
disable mouse scroll on DOM
View Count: 1452
[2016-09-09 04:40:56]
User60518 - Posts: 106
Is it possible to disable the mouse scroll on the DOM?
currently use WIN8 installed on apple mac (dual boot), so the mac mouse can scroll without a wheel and sometimes I accidentally scroll when I dont mean to..... if it cant be disabled I'll just get another mouse....
Date Time Of Last Edit: 2016-09-09 04:42:14
[2016-09-09 04:55:05]
Yes right-click on the scale of numbers and select Interactive Scale Locked.
[2016-09-09 05:52:54]
thanks - does that mean that when I double click I cannot re-centre the dom?
[2016-09-09 06:32:32]
Try it and see. But it does not prevent that.
[2016-09-09 14:52:03]
just to confirm it works - thanks. I can double click the DOm and it centers.
