Date/Time: Fri, 10 Jan 2025 13:15:30 +0000
adjust scale setting to show full order fills
View Count: 663
[2016-09-08 19:07:54]
User565364 - Posts: 10
Hi how do I adjust scale settings to show full order fills? In this chart, my long entry on the second trade is showing the fill triangle only, not the text box.
http://www.sierrachart.com/image.php?Image=1473361457651.png
thank you
[2016-09-08 22:30:24]
You will need to use Interactive Scale Move to move the chart up:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#InteractiveScalingMoveUpDown
