Date/Time: Fri, 10 Jan 2025 12:40:06 +0000
CrossOver from Below and Above
View Count: 1992
[2016-09-08 19:03:08] |
User28914 - Posts: 87 |
I have 2 EMAs and would like to create an alert with an up arrow for when the EMAs cross from below and then a down arrow for when the EMAs cross from above. Please advise. |
[2016-09-08 22:55:26] |
We will put together an example for this.
[2016-09-12 16:08:16] |
Any examples?
[2016-09-12 16:35:55] |
Yes. It is attached. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/DLLUsage.html#UsingStudyCollection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-12 16:57:36
MovingAverageCrossoverWithArrows.StdyCollct - Attached On 2016-09-12 16:35:13 UTC - Size: 37.3 KB - 448 views |
[2016-09-12 16:37:29] |
Please attach again, thank you.
[2016-09-12 16:58:02] |
We apologize. The attachment was private. It is now public. The link is in post #4 at the bottom.
