Date/Time: Fri, 10 Jan 2025 13:10:46 +0000
Missing Instruments
View Count: 910
[2016-09-08 17:00:37] |
User247411 - Posts: 1 |
Is MDAX (Amp Futures' symbol for this instrument is F2MX) futures not available with this platform? Thanks
[2016-09-09 04:36:17] |
if you are looking for the mini DAX, the CQG symbol is: F.US.FDXM?##. You will find this in File >> Find Symbol.
