Date/Time: Fri, 10 Jan 2025 13:17:37 +0000
Automatic Rollover
View Count: 649
[2016-09-08 17:00:10] |
User889851 - Posts: 1 |
I am using a chart F.US.EPU16. It has automatically rolled to F.US.EPZ16. I would like to continue to use the U. when I attemt to change back to U in the chart settings, it will not allow it but continues to stay on Z. Please advise on how i can turn off the feature that is automatically rolling the contract forward as most of the volume remains in U. Thank you in advance for your reply.
[2016-09-08 18:31:27] |
The setting for this is Chart >> Chart Settings >>Automatically Rollover Futures Symbol.
