Date/Time: Fri, 10 Jan 2025 13:35:32 +0000
retrieving lost charbooks from C drive
View Count: 975
[2016-09-08 16:23:32] |
User780238 - Posts: 45 |
How do I retrieve lost chartbooks from my C drive? Thank you
[2016-09-08 17:16:03] |
Chartbooks have a cht file extension. So you just need to search your drive for those. Once you have found them, then you need to put them into the folder specified through Global Settings >> General Settings >> Data Files Folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
