Date/Time: Fri, 10 Jan 2025 09:25:42 +0000
rollover
View Count: 670
[2016-09-08 12:53:31] |
User771416 - Posts: 47 |
After rolling over to EMDZ16 this morning, my intraday renko chart does not have the correct volume profile data for previous days. Can anyone tell me where to look to correct this? |
[2016-09-08 17:00:25] |
What you need to do is use the Continuous Futures Contract Chart feature: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
