Date/Time: Fri, 31 Jan 2025 00:27:02 +0000
Change to Risk Reward Tool
View Count: 2017
[2016-09-08 12:42:40] |
User327694 - Posts: 25 |
Currently, if one clicks on the text on the Risk Reward Tool, the context menu allows "Adjust Drawing". If the text is selected, this allows us to move the text vertically. To move the text from left to right of the drawing, we have to go into Chart Drawing Porperties and the deselect "Text On Left". I use this a lot. Would it be possible to add this horizontal Left of text/Right of text functionality with motion of the pointer OR maybe a "Text on Left On/Off" in the context menu? Regardless of the outcome of my request, many thanks for the great work you guys do! |
[2016-09-08 16:51:14] |
No, this is not something we would add because there is quite a lot of involvement in this. We would not even have a chance for more than a year from now.
[2016-09-08 19:24:42] |
That's a shame, I would have thought linking the "Text on Left" toggle into the context menu would have been relatively easy? Thanks in advance. |
[2016-09-08 22:30:55] |
We thought of another way this can be done interactively. We will see if we can implement that in the next few days.
[2016-09-09 14:17:21] |
Many Thanks.
[2019-04-05 14:56:59] |
User161560 - Posts: 19 |
Did you ever get this enabled so we can adjust the location of the text left to right incrementally? Cheers Simon |
[2019-04-05 21:11:19] |
John - SC Support - Posts: 37621 |
Yes, this works in the current release, and for some time now. It allows the text to be moved to the Right or Left of the last entered point on the Reward/Risk Tool. This is the same as selecting the option for Text On Left on the Chart Drawing Properties for the Reward/Risk Tool. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-05 22:56:52] |
Thanks John. But can you move that text left to right incrementally i.e. a little bit left and right rather than just all the way left or right like you can adjust the vertical alignment incrementally?
Date Time Of Last Edit: 2019-04-05 22:57:28
[2019-04-06 16:04:17] |
No, that is not supported. We will add your request to our list of requests, but it will be a long time before we will be able to get to this, truthfully, if we ever can get to it. There are a lot of other higher priority items.
