Date/Time: Sat, 11 Jan 2025 09:43:26 +0000
Additional Zig Zag display
View Count: 1697
[2016-09-07 23:40:12] |
User50927 - Posts: 91 |
Would it be possible for your team to add an option in the Zig Zag indicator to display the following: Zig Zag volume divided by the Zig Zag length (points or ticks)? Normalizing the volume allow for more meaningful comparisons across swings. Thank you.
[2016-10-09 18:41:51] |
I understand that you are very busy but I haven't heard anything about this posting in over a month and I was still wondering whether you could make this tiny modification to the Zig-Zag indicator in the near future. It would go a long way toward interpreting the data at a glance by allowing an apples-to-apples comparison across swings. Thank you.
[2016-10-19 23:16:33] |
This is still pending review.
[2016-11-20 01:53:46] |
We are doing this now.
[2016-11-20 02:03:29] |
This will be out in the next release.
[2016-11-29 23:36:34] |
Just wondering if the ZigZag display option I requested has already been released since I was told that it would be out in the next release nine days ago. I can see "Display ZigZag Volume / Bars" in the study but not the "Display ZigZag Volume / Point". Since the study already calculates and display both the volume per swing and the points per swings I assume that the the ratio of the two can also be displayed, unless I'm overlooking something. Thanks.
[2016-11-29 23:57:31] |
Yes that is what was added, but we see you want to have the Volume divided by the price range. So we will change it to that.
