Date/Time: Thu, 19 Sep 2024 21:26:40 +0000
Copy Chart Drawings - lines are misplaced
View Count: 1267
[2013-07-23 12:32:06] |
timokrates - Posts: 28 |
Hi, I'm copying lines from the daily to the 1min chart. But as you can see in the pic, the line does not display correctly, it's far of. What can I do to solve this vital issue? Thanks! |
[2013-07-23 17:52:06] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?l=doc/helpdetails34.html#ChartDrawingsMisaligned Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
