Date/Time: Fri, 10 Jan 2025 09:32:50 +0000
HL Avg on Compact Tools Value Window
View Count: 812
[2016-09-07 17:15:25] |
User28914 - Posts: 87 |
Please see below and attached. It’s not updating with the HL Avg on my Compact Tools Values Window.
jjchart2.png / V - Attached On 2016-09-07 17:14:51 UTC - Size: 99.31 KB - 249 views |
[2016-09-07 18:17:23] |
The Compact Tool Values Window does not display the bar average values. You need to use the Tool Values Window: http://www.sierrachart.com/index.php?page=doc/Tools.html#ViewingToolandChartData And that can be customized as explained here: http://www.sierrachart.com/index.php?page=doc/helpdetails67.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
