Date/Time: Fri, 10 Jan 2025 09:56:24 +0000
HOW TO CANCEL ORDERS
View Count: 762
[2016-09-07 12:13:40] |
User82615 - Posts: 106 |
HELLO I'M TRYING TO DESIGN A TRADING SYSTEM THAT AT THE OPEN OF THE DAY SENDS A BUY STOP ORDER AND ALSO A DIFFERENT SELL STOP ORDER. BUT T WANT THAT WHEN EITHER OF THOSE ORDERS IS EXECUTED THE OTHER ORDER IS CANCELLED. CAN ANY BODY TELL ME HOW TO DO THIS , BECAUSE IN BACKTESTING THIS STRATEGY WHEN ONE ORDER IS EXECUTED THE OTHER ORDER STILL CONTNUES ALIVE. THANK YOU VERY MUCH |
[2016-09-07 17:23:28] |
You need to use this Order Type which is also supported from ACSIL: http://www.sierrachart.com/index.php?page=doc/OrderTypes.html#OCOBuyStopSellStop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
