Date/Time: Fri, 10 Jan 2025 09:30:16 +0000
NKD
View Count: 934
[2016-09-07 06:15:41] |
sellis67 - Posts: 105 |
Trade closed, trade amount not updated. There was a previous trade and the trade closed and updated. Using TopStep combine sim. Need to know if this is a TopStep issue.
[2016-09-07 06:19:07] |
Trade Activity Log: File read result: 13592 records inserted. 0 records filtered. | 2016-09-06 19:28:40 Trade Activity Log: File date-time limits: Sim records date-time limit is 2016-08-23 00:00:00. Non-sim records date-time limit is 2016-06-06 00:00:00. Non-sim fill record date-time limit is 2015-09-08 00:00:00. | 2016-09-06 19:28:40 CTS T4 FIX | Received LastRptRequested in execution report for account: sellis67Sep07CC | 2016-09-06 19:28:57 CTS T4 FIX | Received LastRptRequested in execution report for account: sellis67Sep07CC. Inserting missing order fills. | 2016-09-06 19:29:07 Unable to Flatten or Reverse because a Position does not exist. Working orders will be canceled | Symbol: NKD.20160900.CME_Eq | TradeAccount: sellis67Sep07CC | 2016-09-06 22:41:07 * |
[2016-09-07 06:23:00] |
We to know where in Sierra Chart you are referring to "trade amount"? And we need to know the exact descriptive name as it is used within Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-07 06:23:19
[2016-09-08 01:12:42] |
Trade Activity Log: File read result: 14611 records inserted. 116 records filtered. | 2016-09-07 17:42:06 Trade Activity Log: File date-time limits: Sim records date-time limit is 2016-08-24 00:00:00. Non-sim records date-time limit is 2016-06-07 00:00:00. Non-sim fill record date-time limit is 2015-09-09 00:00:00. | 2016-09-07 17:42:06 CTS order update (Rejected). Info: Too close to market last trading time, NewMargin: [20.00]. Internal Order ID: 11988. Service Order ID: EDCD8006-0E13-4CD9-8D0C-C810AB1FAD6D. Symbol: NKD.20160900.CME_Eq | 2016-09-07 17:56:51 * CTS order update (Rejected). Info: Too close to market last trading time, NewMargin: [20.00]. Internal Order ID: 11991. Service Order ID: D7B927AF-F29E-46FD-B17E-3714CBE19320. Symbol: NKD.20160900.CME_Eq | 2016-09-07 17:57:36 * CTS order update (Rejected). Info: Too close to market last trading time, NewMargin: [20.00]. Internal Order ID: 11994. Service Order ID: 6F95207C-01DC-4E30-A4F4-3C2C7E9E4816. Symbol: NKD.20160900.CME_Eq | 2016-09-07 18:10:39 * |
[2016-09-08 02:15:48] |
This message: Info: Too close to market last trading time, NewMargin: [20.00]
Originates from the CTS system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-08 02:55:07] |
Ok
