Date/Time: Fri, 10 Jan 2025 16:20:15 +0000
Is there a way to send email alert at a fill please
View Count: 1172
[2016-09-07 01:59:26] |
aydex - Posts: 110 |
Is there a way to send email alert at a fill please?
[2016-09-07 02:26:55] |
There are order fill Alert Settings in the General Trade Settings window: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#GeneralTradeSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-07 02:27:33
[2016-09-07 03:06:46] |
User553714 - Posts: 184 |
Hi, I visited the referenced page but I cannot find a way to send an email alert, only a sound alert. I also checked Global Settings >> General Trade Settings but couldn't find a way to set up an email alert? The alert manger messages also reference the inferred ability to set email alerts... "No alert sound/email set" but I also can't seen to find the method to set an email alert? Apologies in advance if I am missing something simple. |
[2016-09-07 05:27:08] |
There are step-by-step instructions to do this which are here: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#ConfiguringAlertNumberInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-07 05:33:35] |
Question regarding "Number of Times to Play This Alert" Does this get set to 0 if no sound alert is required, just an email alert. Trying to find a way to send email without hearing the alert. thanks |
[2016-09-07 05:45:44] |
No, that is not a way to prevent the alert sound from playing. You just need to record a sound file that is empty and has no sound. That would be the way to do it. We will see about adding support for not playing a sound, later on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-28 09:19:02] |
Hi Is there a way to disable the fill email for Simulated trades, please? j |
[2016-09-28 09:37:00] |
Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings You need to make sure the Alert Number you are using for order fills is not set to send an email. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-28 09:56:36] |
Sorry I should have said disable simulated and enable live trades, at the same time. i wish to get mails from live trades and not the sim trades i may take during the same session i am currently receiving both |
[2016-09-28 10:24:23] |
So are you switching in and out of Trade Simulation Mode in Sierra Chart during a trading session?
[2016-09-28 13:41:38] |
yes. i wish to selectively only receive the "real trade" mails thanks if considered to implement as new feature |
[2016-09-28 17:28:47] |
This is not supported and is not an option that we would add. When in Trade Simulation Mode you can change the Alert Number associated with order fill alerts and then make sure that is not set to send an email. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-28 17:29:43
