Date/Time: Fri, 10 Jan 2025 10:01:43 +0000
time & sales
View Count: 701
[2016-09-06 20:21:54] |
User472677 - Posts: 356 |
Hello, I would have expected time and sales to be consistent with rest of sc. In sc default can be set for various settings or a chart. However the consistency seems to break down when it comes to time & sales. There is no way to save ts settings as default. Am I missing something? If this is an oversight, which is very understandable in a program of this complexity, please make ts consistent with rest of sc by allowing settings to be saved as default. I like sc and am trying to help you make sc consistent. Thx |
[2016-09-06 20:43:58] |
The Time and Sales window settings are contained within the chart that it is associated with. When a chart is active and you select "File >> Open Time and Sales Window", then that particular Time and Sales window is associated with the active chart and that always remains. When you duplicate the chart, then the Time and Sales window for the duplicated chart, will have the same settings as the Time and Sales window for the original chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
