Date/Time: Fri, 10 Jan 2025 09:24:52 +0000
hard drive crashed...new SC install - recover config files?
View Count: 699
[2016-09-06 18:43:50] |
User71961 - Posts: 144 |
so my computers hard drive crashed and is toast...i'm reinstalling all software onto new hard drive does SC store chart config files with chart definitions on a sierrachart server...or do i need to recreate them all from scratch myself? |
[2016-09-06 19:57:33] |
If you do not have a backup of the Sierra Chart installation folder from your previous hard drive, then you do have to re-create your configuration and Chartbooks.
