Date/Time: Fri, 10 Jan 2025 09:03:07 +0000
Flatten trade not recognized by SC indicators
View Count: 700
[2016-09-06 14:31:33] |
JohnR - User831573 - Posts: 307 |
I am using Sim trading, and I had a trade this morning, I closed one out using the flatten button, vs using a profit target/trail. It was displayed on the chart, but not calculated in your trade tracing indicators, as you can see in the screen capture. Once I did a recalc on the chart, it did show correctly. Not a big issue, but thought I would report it. JohnR |
Sim trade missing 2016-09-06_10-08-29.jpg / V - Attached On 2016-09-06 14:30:06 UTC - Size: 220.44 KB - 250 views |
[2016-09-06 18:12:44] |
There is no problem with Sierra Chart in this regard. Refer to this section here for detailed information about the possible causes for this issue: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#TradeDataStudiedNoDataMisaligned Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-06 18:14:06
