Date/Time: Fri, 10 Jan 2025 10:04:45 +0000
alerts and notes on charts
View Count: 808
[2016-09-06 14:15:09] |
User170575 - Posts: 221 |
Good morning, Is there a way to see which tickers have notes on their chart? Or which tickers have price alerts from charts? Many thx, Cj |
[2016-09-06 18:16:18] |
You can use the Tools >>Manage Chart Drawings Window: http://www.sierrachart.com/index.php?page=doc/Tools.html#ManageChartDrawings How did you set the Price Alerts? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-06 18:23:58] |
From the chart--"add symbol alert."
[2016-09-06 22:33:10] |
To see all of the existing Symbol Alerts, go to the Alerts Manager. This is documented here: Alerts Manager: Symbol Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-07 18:10:24] |
So if I closed a chart that had text notes on it by accident---is there a way to recover it? I am not showing anything in the Manage Chart Drawings Window. Thx Cj |
[2016-09-07 18:14:47] |
Yes there is. And it is documented here: http://www.sierrachart.com/index.php?page=doc/Chartbooks.html#RestoringPriorStateOfChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-07 18:47:01] |
awesome---many thx
