Date/Time: Fri, 10 Jan 2025 09:36:53 +0000
time difference study on range bar/price bar/volume bar etc...
View Count: 966
[2016-09-06 13:54:01] |
hursthead - Posts: 28 |
hi, i am trying to find a study or function on SC that allows me to see the time it takes to print a range bar, lets say 2 ticks, or any type of price bar or volume bar. i want the time difference (delta) shown as a histogram/bar format below the chart. is that possible on SC? thank you. |
[2016-09-06 15:42:56] |
TechTrader - Posts: 116 |
Analysis > Studies - scroll down to 'Bar Time Duration' > Add>>
[2016-09-06 17:45:18] |
Use the Bar Time Duration study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s258 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-07 01:01:56] |
thank you for your help. i'm looking to enhance the study - current default setting for each bar time duration is green colour. i wish to make the bar time print green when the price bar prints a high bar and vice versa print a red bar in the bar time when the price bar is down.
[2016-09-07 05:34:18] |
For this, use the Color Bar Based on Alert Condition study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s245 You will need to add 2 instances of the study. One for each color. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-07 06:04:29] |
Here's another method - Highlight the study > Settings > Subgraphs > Auto-Coloring select 'Based on Slope' from the drop down menu and then choose your colors for up and down bars, > Apply > OK
[2016-09-07 07:24:01] |
thank you. so helpful. since you brought up color bar based on alert condition i have another question. can i just check that if i want to reference the previous bar close it is c[-1] on alert and previous 2 bar close is c[-2] and etc? i wish to highlight the bar or have an arrow bar when there is a 3 bar formation up or down. is that possible?
[2016-09-07 07:45:29] |
hi ignore that request. i managed to do it using colour bars. however when i tried to change to arrow bars to show on top of the price bar, the price bar chart is compressed whilst the arrow sits at the bottom of the y-scale. is there a way around it or do i have to use colour bars only? not sure if you understand what i mean by that? thanks.
[2016-09-07 17:03:33] |
Here are step-by-step instructions to accomplish this: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s252_DrawingArrowsAtHighOrLowOfBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
