Date/Time: Fri, 10 Jan 2025 08:53:41 +0000
Historical Data
View Count: 714
[2016-09-05 22:48:59] |
User25309 - Posts: 19 |
I'm unable to download Historical Data whether from IB, or SC data.
[2016-09-06 00:57:55] |
Follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart And make sure you are using one of the symbols listed in File >> Find Symbol which are based based upon the current Service selected in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-06 01:25:47
