Date/Time: Fri, 10 Jan 2025 17:36:31 +0000
DailyClose price data
View Count: 1155
[2016-09-04 22:47:44] |
bala - Posts: 74 |
Please refer to the file the scsymboldata.h . The following are defined: float DailyHigh; float DailyLow; float DailyOpen; I don't find DailyClose defined. Is the close defined in daily and intraday data? |
[2016-09-04 22:56:31] |
You need to use the SettlementPrice field/member.
[2016-09-28 12:48:43] |
Bedhog - Posts: 179 |
Every day I manually draw a horizontal line at the settlement price with a simple alert. I do not wish to use the Close value of an OHLC study because they are using session times. Is there a way to get SettlementPrice printed on the chart without ACSIL? Thank you. |
horizontal-line-for-settlementprice.jpg / V - Attached On 2016-09-28 12:47:15 UTC - Size: 90.59 KB - 327 views |
[2016-09-28 17:34:29] |
Yes. You can use the Daily OHLC study and have it reference a Historical Daily chart: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s137 Also in Alert Formulas you can use this identifier: PREVIOUSDAYCLOSE Although not sure how that would help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-28 18:45:59] |
Settlement for NQ on 09/27/16 is 4860.75 in the QuoteBoard SettlementPrice and it matches the CME website. http://www.cmegroup.com/trading/equity-index/us-index/e-mini-nasdaq-100_quotes_settlements_futures.html This is good. However, the Closing price on a Historical Daily Chart with OHLC is 4815.00. How did you get the Settlement price out of the OHLC study on a historical Daily? Date Time Of Last Edit: 2016-09-28 18:46:09
settlement-vs-close.jpg / V - Attached On 2016-09-28 18:44:07 UTC - Size: 135.28 KB - 345 views |
[2016-09-28 19:22:11] |
This is not what we see: http://www.sierrachart.com/image.php?Image=1475090521168.png Also we do not know what is the opening and closing values of those candlesticks in your chart. It is not obvious. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-28 19:22:23
[2016-09-28 19:52:32] |
Here is a historical daily chart with ohlc bars and the daily ohlc study. The close is still 4815.00 which is different than settlement of 4860.75.
historical-chart-daily-ohlc.jpg / V - Attached On 2016-09-28 19:52:22 UTC - Size: 146.33 KB - 284 views |
[2016-09-28 20:05:50] |
Refer to help topic 2.2: http://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.2 The bar for 9-27 is wrong. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-28 22:30:51] |
Yes, the bar was wrong. After 5pm cst today I disconnected and re-connected. That was enough to update the SettlementPrice in the Quoteboard but not the historical charts. The historical chart for YM and NQ updated only after I selected Edit; Delete All Data And Download. Will I have to delete and download the historical data for each symbol, each day, after 5pm to update the OHLC Study containing the correct SettlementPrice? |
[2016-09-28 23:14:11] |
Since the prior to last bar in the chart was incorrect, all you needed to do was select Edit >> Download Data-Historical Chart. Or Edit >> Download Data for All Historical Charts. You do not have to do this every time. This is unusual. Since you are using CTS, you may want to consider the new connection model which we will be releasing this week: New CTS Order Routing Connection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-30 14:20:27] |
NQ SettlementPrice in the quoteboard is 4868.25 and the OHLC Close on the NQ Historical Chart is 4844.25 after repeated Edit;Delete / Edit; Download; ...
no-settle.jpg / V - Attached On 2016-09-30 14:20:22 UTC - Size: 98.96 KB - 307 views |
[2016-09-30 16:51:30] |
The chart is correct. To correct the Quote Board value you need to reconnect the data feed. This is purely an issue with how the CTS data feed works. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
