Date/Time: Fri, 10 Jan 2025 08:54:30 +0000
QUOTE SPREADSHEET
View Count: 932
[2016-09-04 20:46:02] |
User82486 - Posts: 43 |
I KNOW HOW TO OPEN A NEW ONE AND TO SET THE SETTING ON GLOBAL SETTING. I AM CONGUSED WHEN IT COMES TO ADDING MY OW COLUMS TO MY PROPOSED PURCHASSE PRICE AND ANOTHER COLUME THAT CALCULATES THE DIFFEWERENCE OF THE EXISTING LAST PRICE TO A COLUME WHERE I ENTERED A PROPOSED ENTRY PRICE. I AM FAIRLY FAMILIAR WITH EXCEL BUT WHEN I CREATE A FORMULA AT THE TOP OF A COLUME WHY CAN'T I DRAG IT DOWN THROUGH ALL OF THE ROWS THAT CONTAIN DATA FOR OTHER SYMBOLD. I HAVE TRIED THIS MANYTIMES AND I HAVE ALSO TRIED IT USING COLUMS HIGHER THAN k. dO I HAVE TO PIT A NEW FSORMULA FOR EACH SYMBOL IF THEY ARE NOT DRAGABLE AS IN EXCEL? FRED |
[2016-09-05 10:54:45] |
The way this is done is documented here: https://www.sierrachart.com/index.php?page=doc/Spreadsheets.html#Filling You need to use the Spreadsheet >> Copy* commands. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
