Date/Time: Fri, 10 Jan 2025 08:54:15 +0000
Error modifying target
View Count: 854
[2016-09-04 06:05:12] |
Mistic - Posts: 76 |
I'm using the 'trade management by study' and initial balance study. After i place the order, i wait 30 seconds to what i have 'N set to. I get this error "Chart: Replay 30.0X: CLV6-NYMEX 500 Trades #23 | Study: Trade Management by Study | There is not a new price to modify the order to. | 2016-09-03 22:59:46" The initial target was never changed to the study subgraph i selected. Any suggestions why? Also, Is there a way to be more specific on which target to change if i choose to add more targets? Thank you Ben |
[2016-09-04 10:50:07] |
In the next release this log message will be enhanced to show the actual existing order price and the calculated price from the study subgraph. The problem is very simply that there is not a new price to modify the order to. The price is already at the price of the study subgraph with the offset. Only the nearest Stop or Target is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-04 18:35:20] |
Thank you. It was the offset that was the problem. Got another question. Can the 'trade management by study' be enabled through spreadsheet when price reaches a new target? I'm trying to find a way to have multiple targets and 1 stop, as price moves through each target, the stop gets adjusted to prior target (all targets and stop linked to IB study price levels). |
[2016-09-04 21:02:38] |
No. You will have to modify the study to accomplish what you want. Refer to: https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
