Date/Time: Fri, 10 Jan 2025 08:50:35 +0000
More order inputs from Chart DOM settings
View Count: 667
[2016-09-03 18:05:15] |
Napoleon Dynamite - Posts: 54 Invalid SC Account Name. |
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=9048 Hello, please refer to the screenshot. I'd like Sierra to add more order inputs types than only Buy/Sell Limit and Buy/Sell stop from the dropdown list. I would like to be able to set MIT orders for instant Please consider it for an update. Thx |
Attachment Deleted. |
[2016-09-03 22:49:52] |
This is already supported. Refer to step 6 here: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
