Date/Time: Fri, 10 Jan 2025 09:13:55 +0000
EMA200 Value depends on Days to load
View Count: 692
[2016-09-03 16:17:15] |
nicktrader - Posts: 725 |
In this chart I am using an EMA200. However I get different values if I load different days. The correct value = 10178.4 = 1500 Days. Pls take also a look at 600Days. That value is higher than 1000 or 1500 Days What is the problem and how can I fix it? |
400Days.png / V - Attached On 2016-09-03 16:12:21 UTC - Size: 96.67 KB - 231 views 600Days.png / V - Attached On 2016-09-03 16:12:28 UTC - Size: 43.55 KB - 205 views 1000Days.png / V - Attached On 2016-09-03 16:12:36 UTC - Size: 45.98 KB - 214 views 1500Days.png / V - Attached On 2016-09-03 16:12:44 UTC - Size: 46 KB - 200 views |
[2016-09-03 22:36:59] |
There is no need to have posted all of this. This is documented here: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s27 It really is a mistake to use an exponential moving average over a long period of time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
