Date/Time: Fri, 10 Jan 2025 08:48:12 +0000
Access to SC feed while connected to LMAX
View Count: 689
[2016-09-03 13:07:17] |
gomifromparis - Posts: 244 |
Hi, I'm connected on LMAX DTC and would like to be able to simulateously watch FDAX using the SC feed. I selected "use sierra feed" but futures don't show up. Thanks |
[2016-09-03 23:13:35] |
You need to install another copy of Sierra Chart on your system to use the Sierra Chart Exchange Data Feed. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
