Date/Time: Fri, 10 Jan 2025 09:02:29 +0000
NOTICE: New Custom Studies DLL Compiler/Solution to Compile Error Issue
View Count: 4181
[2016-09-03 00:43:47] |
The custom studies compiler invoked with Analysis >> Build Custom Studies DLL >> Build Custom Studies DLL with versions 1458 and earlier may encounter a problem when using a new installation of the supplied compiler. We do not recommend using the previously used compiler. Version 1459 and higher of Sierra Chart now use the MS Visual C++ compiler which is more reliable. If you are building custom studies, we recommend updating to version 1459 at this time and if you are encountering any compiler error issues, you must update to version 1459 at this time. 1459 at this time is the Prerelease. Update with Help >> Prerelease. Here are detailed instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You will also need to install the Visual C++ builds tools. Use this link: http://go.microsoft.com/fwlink/?LinkId=691126 Let us know if you have any difficulties. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-03 23:51:34
[2016-09-03 23:52:55] |
Version 1459 is now the main release of Sierra Chart.
