Date/Time: Fri, 10 Jan 2025 10:06:24 +0000
Stop Limit Inconsistencies
View Count: 785
[2016-09-02 16:51:08]
dBassFour - Posts: 16
The question is within the image.
My Attache orders are using the the STOP Trigger price, not the LIMIT/Entry price, which is a 1 tick improvement.
I cannot get the attached orders to adjust based on my ENTRY price.
_Dion
image2016-09-02_1209.png / V - Attached On 2016-09-02 16:51:04 UTC - Size: 153.81 KB - 234 views
[2016-09-02 17:48:42]
The Target and Stop orders will be adjusted based upon the fill price of the Stop order.
Disable this option:
http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideOCO
And make sure this option is enabled:
http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#AdjustAttachedOrders
Date Time Of Last Edit: 2016-09-02 17:49:06
[2016-09-02 17:50:24]
If you want to have a consistent result, you will need to use a Stop-Limit Order Limit Offset of 0.
[2016-09-02 18:26:52]
Are you suggesting I use LOCAL execution in order for my Attached orders to be based on my fill?
Is there no way to have OCO orders that are based off of my Fill Price? I mean even if it was a MARKET order, do your attached orders never adjust unless disable Server Side OCO?
The second response, I dont even understand because it wasn't the question I asked. The whole point is that I want one tick improvement on my STOP-LIMIT orders with attached orders to match the LIMIT order/parent order fill.
Thanks,
Dion
[2016-09-02 18:32:59]
What you need to do is disable server side bracket orders. That is a requirement to accomplish what you want.
For the Target and Stop order offsets to remain identical like they were before the order fill, you must also have this option enabled:
Date Time Of Last Edit: 2016-09-02 18:40:03
[2016-09-02 18:34:25]
One moment. We have to reword what we said in post #5. It is not completely correct.
[2016-09-02 18:41:19]
Post #5 has now been revised. Reload this page.
There is a new connection model that we are developing with CTS that will be released this month. It is documented here:
http://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel
With this connection to CTS, you can have server-side bracket orders which automatically will adjust the Attached Orders to maintain the same offset as they had before the parent fill, when the parent fills.
Date Time Of Last Edit: 2016-09-02 18:41:34
