Date/Time: Fri, 10 Jan 2025 10:04:38 +0000
Charts update
View Count: 656
[2016-09-02 13:44:40] |
User26753 - Posts: 43 |
What is the reason that in a charbook (1) some charts are updated in real time (2) and others not (3)? Most important, how can I fix it? it is very difficult to work in this way
Chartbook 1.PNG / V - Attached On 2016-09-02 13:44:13 UTC - Size: 88.28 KB - 189 views Chartbook 2.PNG / V - Attached On 2016-09-02 13:44:18 UTC - Size: 81.11 KB - 200 views Chartbook 3.PNG / V - Attached On 2016-09-02 13:44:26 UTC - Size: 71.74 KB - 194 views |
[2016-09-02 18:15:14] |
Refer to help topic 3.4: http://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 However, you probably will need to use the correct Interactive Brokers symbol. Refer to: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock You will need to use a more complete symbol specification rather than just a single symbol. You probably will need to use this symbol format: Stocks With Specified Exchange and Primary Exchange Format. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-02 18:15:48
