Date/Time: Fri, 10 Jan 2025 10:05:05 +0000
Including time in CV Bars
View Count: 785
[2016-09-02 12:56:03] |
User24187 - Posts: 54 |
Is it possible to color Constant Volume Bars in various shades to reflect Bar intensity, where intensity is defined as: Volume/Time taken to form Volume |
[2016-09-02 17:59:30] |
Yes you can use multiple instances of the Color Bar Based on Alert Condition study (One for each color): http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s245 Which would reference a Bar Time Duration study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s258 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
