Date/Time: Fri, 10 Jan 2025 09:34:07 +0000
adding a stop order to a running position
View Count: 930
[2016-09-02 12:34:41] |
moya - Posts: 19 |
Hello, How can I add manually a stop once my order has already been filled ? Thank you very much |
[2016-09-02 17:57:15] |
If you just want to add a single Stop order, then you just simply enter it using the normal method. Refer to this page: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
