Date/Time: Tue, 26 Nov 2024 11:56:13 +0000
Renko Chart - 2 input values
View Count: 1538
[2016-09-02 11:56:23]
markuz - Posts: 90
Is it possible to create a Renko chart but having two input values. 1 is the renko bar in ticks and another is the trend threshold. I was directed to this webpage as a reference of what it looks like. Please let me know, thanks.
http://ninza.co/product/ninzarenko
[2016-09-02 17:54:07]
Yes this is available. It is called Flex Renko in Sierra Chart. It is documented here:
http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html
Also, if what we currently have is not exactly what you need, in the next couple weeks we are adding a new type of Renko bar that should be the same. At least we think.
Date Time Of Last Edit: 2016-09-02 17:54:37
[2023-11-29 20:33:32]
User953554 - Posts: 9
Did this new type of Renko Bar you mentioned get made?
[2023-11-30 16:08:16]
John - SC Support - Posts: 36286
Yes. Refer to the following:
Renko Bar Charts
