Date/Time: Fri, 10 Jan 2025 09:44:54 +0000
Importing Horizontal Lines from a file
View Count: 964
[2016-09-02 09:34:25] |
User34424 - Posts: 21 |
Is it possible to import studies from a file? I want to get Horizontal Lines from a text/csv file |
[2016-09-02 09:46:43] |
Yes but you will have to develop this yourself using ACSIL: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
