Date/Time: Fri, 10 Jan 2025 13:57:59 +0000
Background color for locked space
View Count: 777
[2016-09-02 04:37:12]
nicktrader - Posts: 725
As you can see as example the color for the chart is different to the locked space. I manage this with the "Time Range Highlight" Study.
Isn't it possible to add the option in Graphics Settings "Chart Background locked space"?
imageGraphics Settings Background.png / V - Attached On 2016-09-02 04:32:39 UTC - Size: 21.11 KB - 252 views
[2016-09-17 09:31:20]
Do you think about that?
[2016-09-17 09:50:18]
Refer to:
Notice: Suggestions (Currently not accepting)
We have no further comment.
[2016-09-17 11:00:13]
It is possible to modify the Time Range Highlight study to color the right side fill space. Refer to:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
