Date/Time: Fri, 10 Jan 2025 09:48:45 +0000
STOP ORDER
View Count: 682
[2016-09-01 17:22:12] |
User82615 - Posts: 106 |
HELLO I'M NEW DESIGNING TRADING SYSTEMS AND I'M TRYING TO BUILD A SYSTEM THAT WILL SEND AN STOP BUY ORDER AT THE CLOSE OF THE FIRST BAR OF THE DAY, AND THE STOP PRICE WILL BE THE CLOSE OF THE BAR PLUS THE 0,5% OF THAT CLOSE. I'M TRYING TO BULD IT THIS WAY BUT IT DOESN'T WORK WHEN DOING BACKTESTING. INSTEAD IF I PUT THE CLOSE OF THE BAR PLUS FOR EXAMPLE 10*SC.TICKSIZE IT DOES WORK. AM I DOING SOMETHING WRONG THANK YOU VERY MUCH |
[2016-09-01 20:23:56] |
This is a programming level question. We can only refer you to: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#DebuggingTradingSystems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
