Date/Time: Fri, 10 Jan 2025 09:36:35 +0000
Stuck with old data feed when loading SC
View Count: 611
[2016-09-01 16:21:56] |
User891956 - Posts: 3 |
Hi guys I have changed data feeds from TT FIX over to CQG, SC is supplied by my broker. I have removed the TT credentials and removed connect at startup. I have added my CQG credentials and selected connect at startup. When I load SC I get TT trying to connect. I can not figure out how to stop TT trying to connect and to load CQG at startup. Any ideas? Baldur |
[2016-09-01 18:17:01] |
This is now resolved for your account and the Service will not switch back to TT any longer.
