Date/Time: Fri, 10 Jan 2025 09:30:10 +0000
Sim testing 2 different chart books at the same time
View Count: 760
[2016-09-01 15:20:57] |
John M - Posts: 171 |
Hello, I have 2 automated trading chartbooks for the same trading product, Gold futures. 1 chartbook has XX ticks per bar, the other has YY ticks period per bar, ie they are different and I want to compare the results live. If I run these simultaneously, will each chartbook keep track of its results separately or will they be merged/considered one thing in simulation and the results combined? Thank you |
[2016-09-01 17:42:22] |
To do this, each trading system needs to use a different Trade Account. Refer to: http://www.sierrachart.com/index.php?page=doc/AutoTradeManagment.php#MultipleAutomatedTradingSystems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
