Date/Time: Fri, 10 Jan 2025 09:57:42 +0000
Can I be connected on two computers at the same time?
View Count: 1065
[2016-09-01 08:46:35] |
User292365 - Posts: 20 |
Is it possible for me to be on two laptops, connected at the same time? One one laptop I want to follow a scalping trade, on the other I want to study. Maybe if on one computer I log in with my real info, and the other one I keep it demo, I can do this. But, can I open up my accounts simultaneously on two different computers? |
[2016-09-01 09:49:18] |
Yes you can definitely run Sierra Chart on two computers at the same time. You may not be able to connect to the particular Date or Trading service you are using at the same time, but the solution to that is to use the DTC server which is documented here: Data and Trading Communications (DTC) Protocol Server: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
