Date/Time: Fri, 10 Jan 2025 09:39:04 +0000
"Volume per bar" to a control button
View Count: 774
[2016-09-01 04:18:10] |
chifounou1 - Posts: 13 |
Hi, I haven't found how to add a control button to the control bar that can control the period type "Volume per bar" from ChartSeries Can you help ? Thx |
[2016-09-01 06:58:20] |
This is documented here: Control Bar: Custom Buttons for Intraday Chart Bar Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-01 12:09:16] |
Thank you
[2016-09-01 16:24:20] |
There is no need to say thank you.
