Date/Time: Fri, 10 Jan 2025 08:46:49 +0000
Ver 1457 - Continuous Contract Sysmbols
View Count: 666
[2016-08-31 16:36:36]
NRGTrader - Posts: 351
I updated to V1457 and my old charts using symbols like CL# now show no data. Did the format change?
[2016-08-31 16:39:18]
Those symbols are still supported.
In the first revision of 1457 there might have been a problem with this because you may have set the Continuous Contract option in Chart >> Chart Settings to a setting other than None when it should not be.
Update again with Help >> Download Prerelease to get the latest revision.
[2016-08-31 16:44:35]
Thanks! Re-downloaded prerelease V1457 and issue solved.
