Date/Time: Fri, 10 Jan 2025 09:01:13 +0000
Compilation/linking error "cannot find -lpthread"
View Count: 1490
[2016-08-31 15:30:14]
User74271 - Posts: 3
I am just starting to explore ACSIL by following your "Step-By-Step Instructions to Create an Advanced Custom Study Function" on
Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function
When trying to build a new study (any, including the SC example ones), I always get the following:
-- Starting build of Custom Studies Source files: A_trial.cpp. -- 17:21:09
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\A_trial.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "C:\SierraChart\Data\A_trial.dll"
c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/5.3.0/../../../../mingw32/bin/ld.exe: cannot find -lpthread
collect2.exe: error: ld returned 1 exit status
-- End of Build -- 17:21:11
Just reinstalled SC latest version as well as the compiler. Have no idea, how to fix...
Could you provide ahint, please?
F.
imagelpthread_error.png / V - Attached On 2016-08-31 15:29:52 UTC - Size: 35.13 KB - 285 views
[2016-08-31 18:22:12]
We are looking into this.
[2016-08-31 22:47:58]
We are going to use a new compiler and abandon this existing one. We will use the Microsoft Visual C++ compiler. Just give us a couple of days to get this set up.
Install it using this link:
http://go.microsoft.com/fwlink/?LinkId=691126
Use the default installation.
[2016-09-03 00:46:28]
For the solution to this problem, refer to this post here:
NOTICE: New Custom Studies DLL Compiler/Solution to Compile Error Issue
[2016-09-04 14:40:02]
ganz - Posts: 1048
User74271
fyi: How to build ACSIL study on Ubuntu/Linux | Post: 82852
