Date/Time: Fri, 10 Jan 2025 08:58:42 +0000
GOT NEW PC...CAN YOU GET MY OLD CHARTBOOK?
View Count: 693
[2016-08-31 13:58:09] |
User842373 - Posts: 1 |
I have a new PC and I have downloaded the latest version of Sierra. My old PC crashed big time and I was not able to get the one chartbook I had all set of crude oil. The name of the file is Crude Oil. Can you get this file for me from your end? Or do I have to rebuild by chartbook from memory. I did not save it anywhere.
[2016-08-31 16:28:42] |
Sierra Chart - Max - Posts: 5778 |
The chartbooks are only saved on your computer. If you cannot access your old computer and do not have a backup, then you will need to rebuild your chartbook. Sierra Chart Support |
