Date/Time: Fri, 10 Jan 2025 10:02:19 +0000
Export / backup option
View Count: 801
[2016-08-31 12:35:06] |
chifounou1 - Posts: 13 |
Hello, what if I want to pass my whole Sierra configuration (every setting, chartbooks, etc) to someone else or install it on another computer ? Can I export a backup of my configuration in a single file or package ? Thx |
[2016-08-31 16:26:10] |
Sierra Chart - Max - Posts: 5778 |
Refer to help topic 15 here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support |
[2016-09-07 20:58:59] |
Napoleon Dynamite - Posts: 54 Invalid SC Account Name. |
If I transfer my Sierra backup to a friend, will he get my login information when starting the platform ? Is there a way to reset these credentials info first ? Before the backup ?
[2016-09-07 21:07:02] |
Accounts.config (This contains the Data and Trading service related settings including all Usernames and Passwords. Your Sierra Chart Account Name and Password is stored in this file. This file is encrypted.)
Can I clear this file only from the credentials but keep the DTS settings ? Is there a way ? |
[2016-09-07 23:14:11] |
No. It also contains the various external service connection settings in addition to Usernames and Passwords.
