Date/Time: Fri, 10 Jan 2025 09:26:54 +0000
Website translation from a langage menu
View Count: 2128
[2016-08-31 12:32:46] |
chifounou1 - Posts: 13 |
Hello, from another thread you recommended to use http://itools.com/tool/google-translate-web-page-translator to translate your website and documentation. Fair enough, this works. However the average user does not have this reflex. You should add a language icon menu on a corner of your website with major language and use an auto-translate service (I understand you update the content too often to manually translate in many language) If your website was not scary looking for foreign speakers in the first place, I know I would bring you many customers from France, my country. This would be a small change that would make you a lot more mainstream. Right now, many foreign speakers wouldn't bother to look closer. You are missing on something because your software is really very much excellent in all aspects ;) Date Time Of Last Edit: 2016-08-31 12:57:40
[2016-08-31 17:57:34] |
OK we will have a look at this and see what we can do with the Google translate.
[2016-08-31 18:01:59] |
If you are using Google Chrome, it has a feature to automatically translate webpages. You could also look at this plug-in when using Firefox: https://addons.mozilla.org/en-US/firefox/addon/google-translator-for-firefox/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-31 18:02:15] |
Here is one for Internet Explorer: http://www.google.com/intl/en_uk/toolbar/ie/index.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-31 20:03:15] |
Yes thank you. I can manage such extensions, however people again do not have such reflex. I really believe you should add a language switch button from within your website Please have a look here. https://translate.google.com/manager/website/ Maybe you could integrate this feature |
[2016-08-31 21:26:39] |
The issue with having this on the site (and not browser), is that it would break the links to pages requiring login.
