Date/Time: Fri, 10 Jan 2025 09:47:01 +0000
OPERATE WITH NASDAQ STOCKS
View Count: 951
[2016-08-31 12:28:05] |
User82615 - Posts: 106 |
HELLO I WANT TO OPERATE WITH A TRADING SYSTEM THAT I HAVE CREATED IN SIERRA CHARTS ,WITH MY BROKER THAT IS INTERACTIVEBROKERS BUT WHERE DO I GET THE DATA OF THE NASDAQ STOCKS FROM? FROM INTERACTIVEBROKERS OR FROM TELETRADER? THANK YOU VERY MUCH |
[2016-08-31 17:56:20] |
The most reliable source for NASDAQ stock data is going to be by using the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-01 11:05:47] |
BUT COULD I USE THIS DATA SIERRACHARTREALTIMEFUTURESSTOCKDATAFEED FOR TRADING IN MY ACCOUNT IN INTERACTIVEBROKERS (USING MY TRADIND SYSTEM IN SIERRA CHARTS) ? THANK YOU |
[2016-09-01 16:50:09] |
Yes you can. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices You may need to set the Trade and Current Quote Symbol for the chart to the specific symbol used by Interactive Brokers if you want to trade the symbol: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeAndCurrentQuoteSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
