Date/Time: Fri, 10 Jan 2025 08:39:06 +0000
Volume by Price - Last X Bars
View Count: 663
[2016-08-31 12:21:24] |
infpz - Posts: 826 |
Is it possible to have a VBP that continually updates based on the current bar + last X bars? So there is only 1 volume profile present on the graph - for just those 3 bars?
[2016-08-31 17:27:58] |
Yes. You need to set this input: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#InputVolumeGraphPeriodType To: One Period Based On Bar Count Be sure to read over the documentation for setting the other related setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-31 17:30:15
